white sho
I finally got around to replacing my axles on my 90 MTX. The Haynes manual says to not replace both axles at once, so I pulled the right axle and the link shaft. The axle separated from the link shaft easily and it all went back in. The left side also went in easily. Dropped the car off the jack stands and went for a ride. About 2 miles from the house at a steady cruise speed, it was like the axle shafts disconnected. No bang, no noise, just all forward gears, but no movement. The book stated that is you were pulling both axles at once, then you must insert a wooden dowel in place of the axle to keep differential side gears supported. Otherwise they fall in the case and you are in deep doo doo. I got it home and parked it without looking underneath. Are the axles perhaps not seated fully. Any clues???
