eacyde
Pinkley Taurus
I did a search and it seems a lot of cars are affected by the no lock, no seat electrical gremlin.
It seems there should be a sticky on how to fix it.
I just picked up a 93 MTX and I too have no locks and no power seats.
Is this an RKE (Remote Keyless Entry Module) I only got keys with the car
I checked the 40AMP fuse under the hood and it is good. There is also 12V at the fuse.
Fuse/Breaker #14 is good. I swapped the horn one to verify. Should I have power at #14? I did not.
Where is the ground by the seat? I removed the trim panel and I found a small ground wire just in front of the trunk/gas lever.
Is there a way to jumper power to the seat so I can at least move it so it is comfortable?
I do have a complete 95 SHO that I can pull parts off.
Thanks.
Thanks.
