No crank and lots of dash lights after engine rebuild
dpracing
Iowa
Hello, I have a 2013 SHO with 187k miles, and I just pulled the motor after the water pump went out and decided to freshen it up a bit. I put in new turbos, pistons, rings, and full seal kit. After reinstalling the motor back into the car, I pressed the button to turn accessory on, everything worked - headlights, taillights, interior lights, dash and screen. after about 2-3 seconds I get bombarded with codes - Low oil pressure, coolant temp, blind spot, start system failure, cross traffic system, adaptive cruise fault.
I initially thought they might just be from sitting for a while and the car needed to be started. I pressed the brake pedal, and its very stiff with no brake lights. I checked the vacuum hoses for holes or cracks and they look and feel brand new yet. When I hit the button with the brake pressed the car shuts off, and from what I've read about cars with similar issues, it is a bad battery or ground.
So I put a new battery in it and tried hooking a jump pack to the new battery to give it a boost and still nothing. I checked the chassis and engine ground cables that I removed to pull the motor and they all tested good to the battery. Just for curiosity I put a jumper cable from the battery to the engine and that didn't help either. I checked fuses to the brake pedal switch under the dash and all the engine fuses and they were all good. I noticed the head temp sensor wires were melted by the plug, figured it probably didn't correlate to the no start, but I replaced it with no change. I am missing the intake air temp sensor that goes into the air box, I have one on the way, but I didn't think this would have any affect on the starting issue. I can't find any more information on these problems, so any help is appreciated.
kryptto
South East, Florida
Inspect the main starter cable and power distribution box connections
Check the transmission range (TR) sensor / neutral safety switch
Verify engine to chassis and powertrain ground sttraps
check the brake pedal switch and stop lamp fuse
Lastly if you have a wiring engine harness ground pin that isn't seated - pushed in making poor contact.
This will be a fun session for sure... but my top thoughts.
raymo23
