cudaz101
So some of ya replied to the thread as requested and most didnt...
I gather that we need a +38MM offset with an 8" wide wheel...CORRECT??
With said wheel at those specs how much room do we have to play with inside the wheel well and with the fenders assuming we are running a stock or close to stock height tire??
OR....Give me any spec wheel on a specific gen car and tell me what the exact clearances are inside and out...
Where are the biggest differances among the early and late generations?? Control arms???
Really until all the outlined questions in the initial post are covered we can't move toward styles etc...
In regards to a Slicer??? I am assuming this is a stock SHO wheel style?? This is probably not going to happen. To make a new cast you have to order a staggering amount of wheels in ONE size ONE spec and ONE finish of over 400+ wheels...I somehow doubt this is going to be achievable. BUT with an existing cast "Mustang Replica" we can adjust the offset and change the bolt pattern. However the hub bore will be 70.80MM, correctable with Hubcentric rings. There is nothing wrong with running rings.
Also...I have to admit that I thought this thread would be getting alot more participation than what it has up to this point.
Thanks for your thoughts and participation...
Brad
Brad
