NEW GEN 3
SHOBLOOD
Tama, IA USA
I am now the proud owner of not one but 2 SHO's. I traded my 97 Avenger for a 96 SHO this past week. It got a sweet paint job. Its gray with like a purple pearl sprayed over top of it. Its high miles but I will take care of it. What kind of miles are you guys running and what should be my first mod?
ROB
91 MTX Mocha
Sho Brotherhood of Iowa
stephen newberg
Ladysmith, BC, Canada
Mine is a young one with on 58,000 km (38,000 miles or so). First mod should be getting a decent cold air intake. There are various forms, but one of the simplest is on the V8SHO site called Porterization. You can make it even simpler by skipping the PVC elbow entirely and just use about 15" of 3" diameter rad hose for big trucks and attach it to the airbox entry with 3 small pop rivets or screws. You have to remove the sax stock intake piping. The V8SHO site has good detail on how to do that also. Before taking out the last bit that goes from the airbox to the inner wheel well, be sure to use it to measure the angle you will have to cut into your rad hose that will replace it so you get a clean attachment to the air box. Mod costs about $10 bucks or less for parts and is worth noticable changes by the seat of your pants power increases.
pax
smn
'98, Black
Mod.Porter intake, K&N panel, SARC cutout, instrumentation cluster, 23mm rear swaybar, 245x50x16 Bridgestone Potenzas
SCOTTDW
Memphis, TN, USA
Install a Magnaflow exhaust system and a K&N Panel filter These are the basics. Next will be an UDP...but this is a more radical step.See Magnaflow.com to further convince youself. I would refrain from drilling holes in your airbox. Most guys regret doing that.
Good luck!
Scott
98SHO
K&N Panel
Magnaflows
32K
Goodyear RSAs
hosbaldosho
