Need a steering column, clock spring and windshield washer bottle.
tracy_s_1993_atx
Plano, Texas
I need the following parts for my 1993 SHO
1) Steering column
2) Good clock spring
3) Windshield washer fluid bottle(inside fender)
Thanks,
Michael
tracy_s_1993_atx
Plano, Texas
Dan,
Thanks as I have been needing to change the column as the steering wheel moves all over(probably bad bearings). And my horn and cruise control does not work due to the damaged clock spring from the steering wheel moving around.
Washer bottle is cracked due to the extreme winter we had here in Texas. I thought I drained the bottle, but I guess I left enough to cause problems.
Thanks,
Michael
SV&HOdan
Pittsburgh PA USA
I have a column (with key) out of a '91 and I'm not sure if gen1 and gen2 are the same. Do you know? I have gen1 and gen3 washer fluid bottles but no gen2. I have
a box of clocksprings somewhere and will keep on looking for it. Unfortunately I am the king of disorganization.
SV&HOdan
Pittsburgh PA USA
...found the box of clocksprings but none with an F3 part number. There are several that begin F1 and several that start out F5...
Irish Pride
Irish Inside
MusicCityUSA
The washer fluid bottles should all be the same, Gen1 or Gen2.
-Chad
tracy_s_1993_atx
Plano, Texas
Question, will the steering column from any Gen 2 Taurus/Sable fit my 1993 SHO? Well as long as the steering column is for a Floor shift and has Tilt and Cruise Control.
Thanks,
Michael
zoomlater
Seattle, WA
on my 92 SHO, the rack is non VAP steering and my 94 MTX/ATX has VAP steering. Shosource has a picture of the two different racks.
