Need a little help
catin379
PA
I bought a 92 SHO about four months ago, it has 137k. It ran great until this morning, I touched up a few rust spots under the hood and left it open to dry. A water pipe burst above it soaking the engine (I mean EVERYTHING under the hood dripping wet). I checked the air cleaner and oil for water was fine, it started first try ran terrible for a few seconds then seemed to idle fine. But when i tried to drive it it had no power sounds like its on 5 cylinders. I know compression is good and it would have to be getting fuel or it wouldn't run at all, Is there a item in the ignition system that i need to take apart and dry, (im new to these motors) or did that h2o fry something important. Any ideas on where to start would be greatly appreciated. Thanks
SHOGUN88
1994 MTX
Langley, BC Canada
A pipe exploded where, in your house?:nut: Check to see if the plug wells have water in them, take all the wires out and dry them out.
Vnuk1
Mr. Mayhem
Minnesota
Suggest using the Tampon method it works great from what I hear if the plug wells are full off water.
catin379
PA
Yeah i lost the water pipe in my house sometime during the night. The only good news is the engines a lot cleaner:woo-hoo:. Thanks for the advice i'll try that tomorrow.
I do not recommend your way of engine cleaning......
Team Dave
SHO n00b
Sacramento, CA
Tampon method?! I'll be damned if that doesn't sound like a pretty good idea.
I wonder if a female thought of it? :theyareontome:
