N2O Plumbing ?
RJ-92
Crappy NYS
I am running a 3.2 intake on the MTX swap. I have a plate blocking off the EGR inlet. After looking at it and thinking, would it be possible or prudent to run you N2O jet where the EGR formerly was?
SHO92
Upper Freehold, NJ
The only problem I can see is that you might have a problem with the nitrous not being evenly distributed throughout the intake. It will have to go counter clockwise around the intake before it made it to the number 6 cylinder, I think. Otherwise the Nitrous would have to be fitting against the incoming air that is moving towards cylinder 1, go past the TB opening, and then to the front bank.
RJ-92
Crappy NYS
Even though the EGR Inlet is on the back of the intake (by the #3 cyl) the plubming opening in the intake is right behind the TB.
SHO--ripper
928 Euro
winsted,CT
I'm not familiar with the 3.2 intakes but i am with N20 :D
Just as long as the nitrous will be sprayed down the center of the intake you SHOuld be good to go :thumb:
