my subframe connectors
rktmn
Well-Known Member
miami
I finally got aroundto building a set of subframe connectors for myself. I decided to use two 1X1 inch square tubing welded together instead of the 1X2 inch.
I figured that the 1" square tubes would be more rigid that the single 1X2 inch.
Is there any advantage? It is definitely a lot more work.
I will try to geth then instaled this week.
Will the SFC make transmit more noise into the cabin?
http://groups.msn.com/JoseAFernandez/cncmachineshop.msnw?action=ShowPhoto&PhotoID=373
Jose
Grifter
New Jersey
SFC's should cause some more vibration but the added stiffness is well worth it.
