SHOstuff
How do you get the air out of the cooling system to make the heater hotter? And ahy isn't it hotter? It was ok 'til I changed my heater core.
you prolly didnt reinsulate the surrounds of the replacement heater core, did you ? now, instead of redirecting the incoming air thru the heater core, its able to pass around it, not allowing the captured heat to be transferred to the passenger cabin.SHOstuff:
from the factory, the heater core has insulation mounted around the edges. this traps any air from bypassing the heater core. when you buy a replacement heater core, the insulation is not on it, you must do it yourself. if you just removed the old core, dropped in a new, and put it back together, thats why your heater is "warm". youre missing that crucial insulation.SHOstuff:
What do you mean reinsulate cause I put it back just like I took it out. Someone else was saying that probably have air in my cooling lines...what do you think?
