motor swap info
fordfreak
va usa
i did a search on this in this first and it yelded very little info on this.
because of the milage on my motor im looking ata rebuild or motor swap so i need a little info to help make the decision
What does it take to swap a 3.0 witha 3.2
I have a manual trans. Thanx
COliveira95
Fall River, MA
fordfreak:
Check out this link:
http://www.shotimes.com/
Under "Modifications" - "Engine Swaps"
SHOnuff93
Dublin, Ca
you put the 3.0 oil pan, and all external accesories onto the 3.0 and it will drop in just like a 3.0
<small>[ January 12, 2004, 02:10 PM: Message edited by: SHOnuff93 ]</small>
fordfreak
va usa
thanks for the shotimes doc. Ok so i just swap the oil pan and the bolt ons and just drop it in ehh does it make a difference that i have a mtx. Will the flywheel just bolt right up? i notice the othe doc talks about te front head mod is that necassary for my 94?
91taurisho
my house, CO
Use the heads from your 3.0. You won't have to worry about it! while you are at it rebuild the heads and maybe have them ported/polished with oversized valves... Just my $.02
SHOnuff93
Dublin, Ca
forgot to mention the front head needs to be modified, there is a small chunk that needs to be cut off, its obvious when u get to that point.
fordfreak
va usa
are the heads that different will i lose something if i decide to keep the 3.0 heads?
91taurisho
my house, CO
fordfreak:
The 3.0 cams are what you want, at least IMO. They give you more power and if you keep them in the 3.0 heads then no modifying is necessary...
rangerj
Brunswick, Ohio
ff,
If the 3.2L engine has a flywheel attached to it you can use yours or the one on the engine. If it has a "Waffle-plate" for an automatic trans, then it has to be removed and your flywheel bolted on.
If you do the swap it would be a good time to have the 3.0 heads checked over by a michine shop. They can grind the valves, check the valve guides, check for any warpage, etc. You should also have the flywheel resurfaced and check the clutch, pressure plate, and thow-out bearing for wear or other problems.
This is one of those "you may as well" type of jobs! rangerj
