Moonroof Woes
SHOtimeFMF
Buffalo,NY
I own a 1989 Sho and my moonroof is giving me some trouble. I dont think its the motor as they dont fail too often although it might be the switch or a fuse. I have no manual so could somone tell me what fuse number crresponds to the moonroof. After i check the fuse i know it must be the switch. Thanx a lot.
Bank of SHO
Vegas
Hello and welcome,
The oem moonroof switch on our cars is a pos. Do a search in this section for "moonfoof problem" without the quotes (yes it is misspelled). There is a link to a site that shows how to wire an inexpensive switch available from Napa. I added some changes I personally made to make it easier. My new switch is doing fine, and I don't expect anymore troubles with it. Don't buy another Ford switch.
Good luck,
Tom
SHOtimeFMF
Buffalo,NY
thanx for the reply. i already did a search before posting and read what u said. i was just wonderin if anyone knew the number fuse that controls the moonroof? thanx again
projectSHO89
SHOless In St L
On an 89, F6 supplies power to the window safety relay. This relay is energized whenever the ignition switch is in ACCY or RUN.
Power to the moonroof motor is supplied by F14 via the normally open contacts of the window safety relay. This same power feed also supplies the other power windows. If they have power, all of the above circuitry is okay.
From the relay, power is routed to the switch on the overhead console. The output of the switch goes to the moonroof relay and the moonroof motor.
Both mentioned relays are located under the dash upwards and to the right of the glovebox. They can be accessed by swinging the glovebox downward.
Steve
SHOtimeFMF
Buffalo,NY
thanks for the help projectsho89. i guess it must be the switch then guys seeing as my windows do work. sweet, my name is steve too....nice to meet u
myculito
