lugnut stud removal (asap please)
kurtis adum
Driver
michigan
i have two broken studs on my driver side hub. how do this things come off. ive been a beating and a drilling, but it just seems to be taken forever and they havnt moved. blah any suggestions
thanx kurt
Racer X
SHO Pilot, Retired
Connecticut
For broken studs, take the wheel and rotor off, get out the BFH, and get to hammerin!
To install, insert by hand, install rotor and wheel, and torque to spec. The final torquing will pull the stud flush with the hub. :thumb:
kurtis adum
Driver
michigan
sweet, thats exactly what i did. i swung the purse at it a few times, she finally gave way
kurt
qiksho
SHO Addict
Fargo, North Dakota
How did you break two lug studs?? Unless they were overtightened they should not break. If they broke going down the road I would definately check your wheel bearing.
Shoaz
Studly dood
Scottsdale, AZ
They'll break from too loose more often than they'll break from too tight.
Studs break, it's not that unusual.
SHOspazz92
Banned
Triad Area, North Carolina.
Or if some unexperienced young kid about two years ago is changing a flat tire and thinks the lug nut needs to be really tight and to do so puts his full body weight on the tire iron and it snaps...not that I know anyone that did that...its all in theory of course.... :oogle:
Sho-Driver
Peter Pan
The Garage.
If you torque down on a hot stud (IE: track use) it can make it all that much easier to break.
kurtis adum
Driver
michigan
i know it happens, actually one happened from taking it off and the other one broke when i was beating off the first , oh well i got 2 new ones now
kurt
mikay
Kentucky
ok i realize that this thread is like 2 years old but id didnt feel the need to start a new one for some simple questions, whats a BFH? and what does torque to spec mean? thanks in advance.
yamahaSHO
E85 whore
Arkansas
BFH = Big Fncking Hammer
Torque is the amount of force it takes to turn the nut. The spec for the wheels is 85 - 105 ft/lbs.
mikay
Kentucky
yea now im actually having trouble getting the caliper off do you unscrew the two torx(sp?) screw on either side of the piston. when i tried to unscrew those two screws i actually broke my torx bit trying to do so.
yamahaSHO
E85 whore
Arkansas
Yes, the caliper is removed from the bracket (ears on pre-94) by removing those bolts.
hawkeye18
Sorta cares
Norfolk, VA
why do you have torx screws? On my calipers, I have 13mm bolts, on the brackets, I have 15mm bolts. You might have to use a combination of PB Blaster and heat (MAPP gas torch). This is, of course, on a Gen 2. If you have a Gen 1 that might be different...
yamahaSHO
E85 whore
Arkansas
Many of the older SHO's originally had torx. My '92 had torx on one side, but not the other.
mikay
Kentucky
because its the front caliper i think. the rear is different it has the 13mm bolts like you were talking about, and yes i do have a g2.
Brett
SHOs before HOs
Minnesnowta
when i first got the new clutch and tune up stuff (plugs wires etc) in my 91 tsi awd, took it out for a spin, was only going to go around the block. The car didnt build full boost prior to this and was now (thanks to the fresh spark). I proceeded to zip around for about 4 or 5 blocks, then i felt a little wobble, then a big wobble. Pulled over, got out, my wheel was angled in and 3 out of 5 lugs were snapped due to practically hand tightening the lugs. :rofl: You live and learn right? IT seems i always learn the hard way...
mikay
Kentucky
yea i was screwing around in it and i floored it around a turn and after that the wheels started to wobble.
