LR window motor issue, is 10 volts enough?
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I replaced the master switch, and the LR door switch, and have 2 motors, I get 10 volts at the motors harness when i push the button. But it dosent work. When I put battery voltage on it, it turns just fine. Maybe I should reverse the polarity and make sure it runs the other way, didn't think of that til now. :) Maybe I spun it, UP, and never seen it go Down. :) ?
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
well the connector on the window motors were the cuplrit. I used my signal tracer, and I could hear the ringing, but it was super faint on the motor side. I cut the connector out, and hard wired it, works like a charm. :)
hawkeye18
Sorta cares
Norfolk, VA
well if it's not that, it sounds like corroded wires/connectors/bad motor. Sorry... :(
Edit: dang, just saw the reply. See, I thought it was a bad connector! (I was just throwing in wires and motor to not sound like a smartass...)
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Oh yea, it was the connector I'm assuming. I snipped both sides of the connector, and used a good old wire nut. :) Works just fine now. Makes me wonder about the other connectors under the hood. :)
Satchmoz
