Lowered the front end today
mholhut
MA
Well, I had a spare hour after mowing the lawn today, so I decided to lower the front end and try to get rid of some of that nasty wheel gap on the SHO.
My first thought was to try and remove the guide on the back of the strut so I could move the hub assembly up the casing. That didn't go too well. There's only one tack weld holding the guide to the strut, but lacking a die grinder/cutter, this simply wasn't going to happen. I tried getting a cutoff wheel on the dremel back there and there just wasn't enough room. That, and I would also run the risk of slicing through a hose or a wire. So, plan B was implemented.
After disconnecting the brake hose holder from the strut, and removing the hub bolt, the assembly moved up and down the strut several inches. I moved the hub assembly up the strut and checked the clearance between the bottom of the strut and the CV boot. With about 3/16" clearance, I scored the top of the hub assembly against the strut casing for a reference and scratched a new alignment hole with an awl against the alignment plate on the back of the strut. I then slid the assembly back down the strut; enough so I cold get see the markings for the new hole clearly. I drilled a small pilot hole in the center of the marking, and followed it up with a 1/2" bit. The hole was still slightly smaller than the bolt diameter, so I used a bit, graciously provided by my neighbor, that I used to hog out the hole to the correct diameter. I don't know what the bit is called, but it looks like a small pine cone. Anyways, it worked brilliantly.
All that was left was to slide the hub assembly up to the score mark on the strut, tap the bolt back through the back side and tightened it, and zip-tie the brake hose retainer to the strut.
Voila, DIY 3/4" drop on the front end! I might try to get a little more drop out of it by grinding down the bottom of the strut casings in the future. Might be able to get another 1/4" drop by doing that. I imagine the rear struts are as easy to do. I also took the liberty to **** the SARC sensor attachement points while I was at it... they were getting kind of noisey.
If anyone in the N.E. region is interested in doing this, drop me a line.
<small>[ May 31, 2002, 01:13 AM: Message edited by: mholhut ]</small>
Mac98SHO
Pine Island, MN
Mike,
This is something I have been pondering for sometime. I am having a hard time visualizing the drilling point, would you be able to an show picture representation of the drilling point?
Thanx
mholhut
MA
Mac98SHO:
No.
wink
If I get a chance tomarrow, I'll disassemble the whole thing and take a pic or two and email it to you.
I dropped both the front and rear over the last couple of weekends. I just cut the tabs off with a reciprocating saw.
SHOntell
**** Rapids, MN US
Why cant you guys live by me!!!. :mad: I want to drop my car without spending the $ for springs. need to get rid of some of that extra space.
By the way, you guys are thumbs_u
Mike
Mac98SHO
Pine Island, MN
Well I was considering doing this Mod to my SHO, but unfortunately I now have assignment. This could be to your benifit SHOntell. I have other things that will take presidence at the moment.(ie tires , tranny cooler), but I maybe moving to Rochester, MN.
If/when I move, we should hook up and lower are cars at the same time. I am not suppose to report to MN until Oct time frame though.
Somethng to keep in mind.
<small>[ June 03, 2002, 03:50 PM: Message edited by: Mac98SHO ]</small>
SHOntell
**** Rapids, MN US
MAC98SHO, that sounds great!!! I can wait that long. I hope to see ya then. otherwise, we will have to get together before that with wuzzzer and lastsho for some fun.
SHODWN, why are you selling???
Mike
Mac98SHO
Pine Island, MN
Hes probally tired of spending money on it, some self induced some of it old age like his Ford Tranny going south for the summer.
mholhut
MA
SHODWN:
Yes your all welcome. thumbs_u
Kirk, you posing as Doug now?
Paul, how did you get a reciprocating saw in there?!?!? Wait.... I don't want to know....
SHO FLY
Nashua, NH
Mike,
Do you know if there is suppose to be a cotter pin going thru the nut on the tie rod ends?
my tie rod let go today, thank god I was only going 25 or so.
let me know,
thanks-
