Lower end bearings
SHO_of_SD
Sioux Falls, SD, USA
The low oil pressure light is coming on on my 93 ATX. I plan to replace the rod bearing for sure but I have a question for you people that have done this before. Can all the main bearings and thrust bearings be done at the same time or is the end bearing not able to be done. I have talked to the parts guys and they could get all my parts. Clevite looks like the only brand thats out there for the SHO. I am replaceing the sending unit at the same time. I figure while I am in there that I may as well go a complete job if it is possible. I'll probibly check the cranks endplay before replacing the thrust. Hopefully this will be the end of my problems with my SHO. I have almost 2500 miles on my new trans and I have the GP rear arms setting in the trunk and bushings on order. Just got to figure what shims I need for the valves to make that tick go away from under my front valve cover and dry up my plug holes. Good thing I can use the hoists at work. Thanks for you replys in advance.
P.S. Anybody here from around Sioux Falls,SD send me some mail. If there is enough we can probibly get a gathering planned sometime.
<small>[ June 09, 2002, 11:29 PM: Message edited by: SHo_Of_SD ]</small>
FIREMT1977
