Low Oil Level Relay?
SLOSHO89
San Luis Obispo, CA
Has any one ever heard of a low oil level relay? This would be on a '91 SHO. I found it in a wiring diagram and it seems to be under the dash and has wires going to the instrument cluster. It has 5 wires coming out of it in this order.... Red/yellow, Gray, Black/lt. blue, Black, White/pink. It looks like it is probably just a small plastic box either black or grey. I know this is kind of a stretch but I figured it was worth a shot. Tomorrow I will probably be searching for it..... :rolleyes:
Efren
The EVTM says it is "Behind lower center of I/P, on LH side of vertical I/P brace".
Look for it to be mounted directly below or adjacent to the horn relay. That one is easy to find if your horn works.
