lost turn signals
rktmn
Well-Known Member
miami
After replacing my radiator and water pump, I lost my 4 turn signals and the emergency 4 way blinkers.
I must have unplugged a connector or damaged a module.
I don't beleive that this is due to a blown fuse.
Anybody have any idea what could have happened and how to fix it?
Thanks.
Jose
rktmn
Well-Known Member
miami
The #1 fuse was blown, I replaced it, but still no turn signals. I guess that I will have to take care of it tomorrow.
I also do not have brake lights.
Thanks.
Jose
rktmn
Well-Known Member
miami
Well, I do not have turn signals, but I have turn lights. I blow the #1 fuse when I step on the brake pedal.
The #5 fuse (turn signal) is OK, but I do not hear the flasher ticking when I egage the turn stalk.
I cannot find the flasher. What does it look like? I imagine that the flasher is bad, and I need to replace it.
Help.
Jose
rktmn
Well-Known Member
miami
I have found the general vecinit of where the flasher is supposed to be located; however, it is so deep under the instrument panel that I still cannot locate it.
Has anybody replaced a flasher, and if so how did you get to it?
It looks like I would have to remove the instrument panel to get to it.
Is there an easier way?
I can see some connectors at the lefthand side, inside the dash, above the fuse panel, but I cannot identify the flasher from underneath the dash.
Jose
rktmn
Well-Known Member
miami
SHO SPD,
What happened? You lost your turn signals and shorted out the brake lights?
I installed an aftermarket ignition switch recently. I wonder if that could be my problem.
You did not have to replace the flasher?
Jose
SHO SPD
SHO member #480
Naples, Florida
Hmmm.. I cant remember if I had brake lights or not, but I didnt have the 4 ways or the thurn signals. It seems like I DID have my brake lights, but it was a few years back, so its hard to remember. But I do know they replaced the ignition switch, and problem was fixed.
