inverse1216
ok heres the low down, recently my cars ce light came on within maybe a day of the light coming on the car has had the following symptoms:
in any gear and at any speed it will randomly drop in rpms at first it would be about 50 to 100 in drop but now its up to 500 in drop causing the car to surge
if i let go of the gas pedal while its surging the rpm drop goes away only to come back within a few minutes. under accelaration the rpm is not present only when keeping at a constant speed does it drop
sometimes the surging will not show itself upon start up if the car sits till the motor is cold and until second start up does it show up, but then sometimes on the first start up after the motor is cold itll show up bout an hour into driving, very random.
after reading some of the other threads ive come to the conclusion that its either
a) the crankshaft position sensor or
b) camshaft position sensor
am i on the right track here or can it be something else?
any advice is much appreciated the car is a daily driver so i need it up and running asap.
also if it matters its a 93 mtx with 73000 miles
thanks again
andy
thanks again
andy
