firstgen89sho
former Slo_SHO
This guide covers both the 90-91 SHO and the 92-5 SHO
I have over 91 pics in this post, so please bear with me.
The reason why I pulled my dash and heater box out was for a few reasons. 1) the BDA (blend door actuator) was failing, sometimes I would not get heat when asked, and would not cool down when asked, and other times it would work fine, 2) had some wiring issues that needed to be taken care of (re-routing and cleaning up) 3) Clutch self-adjuster would not adjust, found that the spring had broken.
Tools Required for the Job:
Flathead Screwdriver
Philips Screwdriver
5.5mm socket
7mm socket
8mm socket
10mm socket
11mm socket
13mm socket
18mm socket(required to remove the seats)
19mm socket
11mm combination wrench
9/16 combination wrench
1/4" ratchet
3/8" ratchet
Torx #27 bit
Torx #20 bit
A/C line disconnect tools (3/4" and 1/2" disconnects required)
catch basin (to catch coolant from lines when disconnected
So, first things first:
Have your A/C System discharged by a qualified professional
I had already done that
Here is a pic of the beginning
I made it a little easier on myself by removing the seats and the center console (also I have a set of newer seats going in)
A view from the backseat of the task that is ahead of us, removal of that behemoth
Disconnect the battery, as we don't need any power inside the vehicle at this point.
Alright, now that the intros have been completed, onto the first thing to remove, the lower dash cover, it is held on by 4 Torx #27 screws
now that, that is out of the way, take your philips screwdriver and undo 2 screws holding the lower scuffplate, 1 screw holding the kick panel and 1 screw holding the lower portion of the A-pillar trim on both the left and right side, and remove the kick panel trim. On the 92 dash, pull back the door weatherstripping, and remove the a-pillar trim on both sides (they are just held on by friction clips)
While you are at it, the A-pillar trim needs to be removed on both the drivers and passengers side, there are 4 philips screws per side that need to come off, and once those are removed, the trim needs to be gently removed. On the 92 dash, pull back the door weatherstripping, and remove the a-pillar trim on both sides (they are just held on by friction clips)
Philips Screwdriver
5.5mm socket
7mm socket
8mm socket
10mm socket
11mm socket
13mm socket
19mm socket
1/4" ratchet
3/8" ratchet
Torx #27 bit
Torx #20 bit
