Lms 91 v8 tune installed 2013 question
Big Mike 74
Going to put the 3 bar sensor in and everything else it requires and load the 93 octane 3 bar tune in a few days.....but with just the 91 2 bar tune on it I should be okay as far as the thermostat goes right? I have the 160 degree one coming for the 93 3 bar tune but do you guys think it's necessary for the 91 tune too? I'm just running the 91 tune until all my parts come in for the 93 3 bar tune should be a few days
RunMySHO
Does your 91 2 bar tune have the fans set up for the lower temp? I would assume not so it really wont matter. You should be ok for a couple of days as long as you stay away from the Steve McQueen Driving....
Livernois Motorsports
SHOForumSponsor
Sponsoring Vendor
Dearborn Heights, MI
If we gave you 91 performance tuning with the 3 BAR support that is for whenever you are unable to get 93. We do not recommend running any tunes that are made for the addition of mods without said mods installed on your car. If you need us to modify the tunes that we built for you, so be it. That is a simple thing to modify, why risk it? We do not charge for retunes or tune updating.
Big Mike 74
True you guys gave me a few
91-2 bar
91-3 bar
93-2 bar
93-3bar
I had ordered all the necessary parts fr you guys for the 93 3 bar tune I just have been crazy with work and haven't gotten around to putting them in, but for now I loaded the 91-2 bar tune just to have a little more snap to the car I wasn't sure if I needed the 160 stat in for that one or if it was safe to run with stock thermostat since its set up for 2 bar
Satchmoz
