HoustinoJillian
name's JUSTIN
those mirrors are sweet. i wish you had a g2, i'd trade you a set of heated turn signal mirrors for a set of tails.
the optidrive has 2 functions. first, it is a voltage regulator, supplying the LEDs with a constant +12 (a +9 version also exists, which i did not use). second, PWM stands for pulse width modulation. basically, instead of providing constant power to the LEDs, it flashes them on/off extremely rapidly, which to our eyes causes a dimming effect. (this is similar to the concept of how TR refresh rates work, by providing still pictures at a faster rate than the eyes can detect difference). the amperage at which the LEDs run is determined by how you wire them. MIne are wired in a series-parallel array, with each string of LEDs resistored to drive the LEDS at 60mA. underdriving the LEDs at 60mA helps with power consumption, heat, and improves LED longevity. you could chose to run LEDs at any amperage using a PWM such as this, it's just the value of the resistor which you use in series with each string that determines the LED amperage.
i guess i was thinking of the g3 SHO that has a separate amber section for the turn signal
Great job! Love the look... it's one of my favorite features on my new ride (of course it came that way, as I am not gifted enough to fab them in
