had to remove front bumper cover
http://www.ecoboostownerforums.com/...l-grilles/?hl=+taurus++front++bumper++removal
(sorry for wrong forum)
The top lights are from amazon,
https://smile.amazon.com/gp/product/B01C86J3DI/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The bottom light bar is from amazon,
https://smile.amazon.com/gp/product/B01N216MYI/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I used 10mm nutserts into the metal bumper to mount the top light brackets, just make sure you measure three times before drilling holes. (I had to drill twice since I mounted them to far forward and couldn't get the bumper cover back on.) Even with the lights mounted as far back as I could, I had to grind off about an inch of the cooling fins to keep from touching the evaporator.
The bottom light bar, I used the bolt towards the center on the radar unit, drivers side for mounting drivers side bracket, then measured across to passenger side and used 1/4inch nutsert on the bottom of the metal bumper. I still needed to extend the light lower to shine through the lower grill. I just used some aluminum angle iron I had laying around.
Wiring was simple, found high beam signal wire to head lights, spliced into it for signal to relays to power up the lights. Used GM style weather pack connectors on lights.
https://www.ebay.com/p/15-Kits-2-3-...e-Connector-Plug/17026933287?iid=152885639742
Relays are waterproof,
https://smile.amazon.com/gp/product/B074FSZWVT/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
aimed lights with a bubble level and matched top and bottom light with metal bumper so they are all the same vertical position
Low beams....
High Beams.....
Sorry I didn't take pictures during install, I started at 7pm and got done with the project at 4am...... wasn't thinking of recording progress.....
First time I used the lights for testing and aiming my reaction was "These are stupid bright" then smiled broadly and giggled
I am pretty happy with the output, I like performance over aesthetics.
Hope this helped, ask any questions you might have, I just kind of went with the flow while installing eveything.
