StealBlueSho
I just took a look a the log that was posted... I didn't see anything really amiss besides yes, the high KR readings. Fueling look goods.. STFT and LTFTs are good... fuel pressure is good...
Only thing I can see that looks funky to me is the target boost vs pre-throttle body sensor vs manifold sensor....
The pre-throttle body map sensor is picking up a bit more pressure than the desired pressure through the whole run... not sure what torries logs look like, but could be interesting cause he leaves the throttle wide open unlike the stock tunes..
To be honest... I am not even sure that would be causing the knock issues as the manifold pressure is below the desired pressure which is normal due to pressure loss in the manifold and throttle body...
Not a lot help I am providing.. .but I can't see any major issues in the logs... when I had a similar issue on my 2010 its was due to a leaky injector but you could see the inability to maintain the correct AFR in my logs. You seems to be hitting target just fine...
