Warren
Hey everyone, went to Sears auto for a wheel alignment. Spent the $80 and they had my car on the lift for about an hour. Here was the before and after. They told me the rear camber is not adjustable. They also had to break the spot welds on the strut towers under the hood to do some adjustments. Is this normal procedure? The spot welds were intact all of this time until now...What is the negative effect if any that the rear camber on both sides is off by -2.3 and -2.0? What would cause this?
Front Left
Camber Actual -0.3 -- Before -1.3
Caster Actual 4.5 -- Before 4.5
Toe Actual -0.01 -- Before -0.14
Front Right
Camber Actual -0.6 -- Before -0.9
Caster Actual 4.6 -- Before 4.6
Toe Actual -0.06 -- Before -0.18
Rear Left
Camber Actual -2.3 -- Before -2.3
Toe Actual 0.04 -- Before 0.00
Rear Right
Camber Actual -2.0 -- Before -2.0
Toe Actual -0.02 -- Before -0.02
Front Left
Front Right
Rear Left
Rear Right
