Just a Thought....
Racer X
SHO Pilot, Retired
Connecticut
As I understand it, the radio controls and HVAC controls on the EATC football share a common PC board. You couldn't just cut out one from the other without adverse effects, like it not working anymore.
SHOspazz92
Banned
Triad Area, North Carolina.
Pssh, Who need Air Conditioning when you can have Some Bumpin' Tunes, Yo'.
-Sam
SuperHO
Mental Patient
St. Joe, MI
I've had some thoughts about that....from the look of things you could probably take all the stereo stuff and just kinda lay it down around the EATC and add in an aftermarket deck. It's possible....just might look a little ******...but you'd have both.
NebraskaSHO
Harumph!
Omaha
Here's the problem, this cable needs to be extended. How I have no F'n idea
NikonPhotos
And my almost... solution
Eclipseradio
CanonDigitalPictures146
It worked and everything, the radio that is. The heater worked too, On Max Temp and Defrost. It got very hot in my car that winter from the fan.
Doesn't anyone remember that I already tried that?
98TRSHO
kalamazoo
I'll just deal with mine the way it is... I'm not the kind that needs a huge booming system anyway with kids and stuff. Personally I think the chopped and put back together is not a great look. I guess it's one thing that you have to deal with is your drawn to the gen3's. I know some have put the CD player in the Ashtray spot but how inconvenient is that when it's so close to your gear shifter?
93rev2sev
Hockeytown
Is there room in the armrest for a head unit?...
thats the first place I would look.
98TRSHO
kalamazoo
That's were I wanted it but Tim told me we couldnt put it there for some reason, I guess I could always move my changer from the trunk to under a seat of something if I wanted to get at it better.
I had a scanner and a CB radio mounted in the arm rest.
The rectangular shape in the center of the dash would never look right. Some have mounted the head units down where the ash tray is successfully. Here is would be less noticable and is locked in place with the shifter when in park.
Console from window
NebraskaSHO
Harumph!
Omaha
Like this? Been there done that. It was functional but very difficult to do anything while driving. IE DANGEROUS!
Console 5
In regards to the ashtray...
NikonPhotos003
Eclipsemounted
This is the best place, hands down. You retain the factory football, although the radio functions do not work. The lights do though. With the shifter in Anything past N you can add Cd's easy. I have the buttons memorized so I can adjust features, songs, volume, etc. on the fly. Especially easy since you can reach it with your hand resting on the shifter.
Also being so low in the dash, and in front of the shifter it's difficult to notice it's there.
ThatShoGuy
michigan
i did mine and still got workin heat and ac its not 100% complete but the long gray wires for mine are the only ones that i need to make longer but once i start to work on it again ill snap some pics for you guys... but i think i got the plan so it will all work with the after market radio :hail: but were see i started to work on it like 3 years ago and forget how i was goin but i know i can finish it..
:biggrin:
NebraskaSHO
Harumph!
Omaha
Wouldn't a remote control solve that issue? Or are they ALL line of sight.
Line of sight, unless it's Infared. You can see my remote is in the cupholder in the picture with the radio in the console. Either way, your probably going to look down at the radio in the console to change songs, etc.
:biggrin:
I got my rear defrost to kick on, otherwise nothing else ever worked after that one time. The cable got pulled out of the board :frown:
SuperHO
Mental Patient
St. Joe, MI
okay....I'm not anything near an electrical genius, but isn't it possible to solder some wiring onto that green plastic cable to extend it?
NebraskaSHO
Harumph!
Omaha
Neither am I. I thought something could be done with the wire to extend it. What, I'm not sure.
NebraskaSHO
Harumph!
Omaha
They make patches for the that green type of "wiring" ???
Hmmmmmmm good thing I didn't throw the old radio/faceplate thing away...
T-Bolt
NY/NJ
Screw all of that. JL Audio makes something they call the CleanSweep. Basically, you run your factory inputs into this unit, it levels out all the inputs, and outputs them, and uses a separate volume control. My friend, who owns a stereo shop, installs them on many cars with factory navigation systems, and I bet it'd work great in a Gen 3.
http://mobile.jlaudio.com/products_cleansweep_pages.php?page_id=94
The box gets installed in a hidden location, and the only way you can tell it isn't stock is the fact that you have a small **** installed wherever you like to control radio volume. It's a thing of beauty.
