LJRuddy
Pop lock n drop
So I had the 2 bolts that hold the rear header to the y-pipe back out. Before I could take it to a local shop to have it fixed (all be damned if i lay on cold wet asphalt when its 15 degrees out just to tighten 2 bolts) I noticed that the CE light would come on and off during the warm up period. I just figured it was from excess fresh air getting into the exhaust causing the rear sensor to be off. I noticed a steep drop in fuel economy from this. Now that the exhaust is fixed, the CE light does not come on but I am wandering if I need to reset the computer and clear the codes. Once an o2 code is tripped, does the computer always default to the maximum A/F settings even though the CE light is not on anymore and the problem is solved?
