JBL amp wiring
munkee
Too busy...
Missoula, MT
Ok. I did use the search for almost 40 minutes yesterday and I still couldn't find the answer to my question.I have the amps from the trunk of a 90 that had a jbl system and I am trying to put it into a car that didn't. I've got all of the plugs figured out but the wiring that comes off of the small black box I am not sure about. I have a red and a black wire (#1) that come out of the sub amp to a plug- from the plug the red wire goes to the little black box and the black wire goes to another plug. There is a black ground wire coming out of the black box that has a star washer terminal on it- then a yellow wire comes out of the black box to the plug with the black wire (#1). The yellow wire on the other side of the plug is thicker and it has been cut. The black wire changes to red on the other side of the plug and then splits into two wires. One side is cut and the other side has a star washer terminal on it. If someone has a wiring diagram it would be greatly appreciated. All of the links to one in past posts that I found were dead. Sorry for the long post. Thanks.
