Is this normal?
wuzzzer
MN Moderator
St Cloud, Minnesota
This is what happens when I'm driving:
Cruising on the highway at 60mph, the tach reads 2100rpm or so. If I let off
the gas just for a second or two and then reapply the gas even slightly, the
revs will jump up to 2500-2600, then after about a second or two they'll drop
back down to 2100. Is this normal?
I notice that it happens at lower speeds, too. This is from just barely
applying any pressure to the pedal, not nearly enough for it to kick down to
a lower gear.
Is this common?? Sorry if I'm being ignorant about something here!
Mark
'97
Porterized
K&N Filtercharger
Rhino mufflers (909 series)
SilverSHO
cartersville
Someone correct me if I'm wrong, but I think it's something in the transmission taking a second to lock up again (torque converter?).
Nick Draudt
90 SHO 133k
Coneless, ACCEL 8.8 wires,
SHO Shop torque limiters, more to come once I'm not completely broke
SaskSHO
Saskatchewan, Canada
Yep, its the torque converter. The V8 SHO has a unusually high converter for factory, I believe its 2800 RPM. Most factory ATX's come with a 1600-1800 RPM converter.
Scott
97 SHO Black 30k
UDP
Porterized Intake W/K&N Panel Filter
Trush Turbo Mufflers
Firestone SZ50 EP 225/50/ZR16
SaskSHO
Scott
97 SHO Black 30k
UDP
