SHOBrad
I'm planning on either TIG welding (my dad is a welder) or pinning the cams myself over Christmas break and I was wondering why pinning makes everyone so nervous? It seems as long as you set the drilling operation up correctly to penetrate straight thought the middle on the sprocket collar and cam and drowned the whole assembly in coolant to keep the heat buildup minimal that making the hole would not be so hard. After that it would simply be reaming it to size, pressing the pin in and tacking both ends with a welder (preferably TIG). Seems pretty straight forward. What type and diameter of pin is used? I assume just a standard hardened steel pin of 1/4" diameter or so. These are pretty damn strong.
Thoughts?
Thanks,
Brad
P.S. I mean no offense to the good companies that offer this service.
<small>[ November 29, 2002, 05:00 PM: Message edited by: SHOBrad ]</small>
Thoughts?
Thanks,
Brad
