roswell998
I have searched the Forum and if this subject is definitively answered I overlooked it:
1. Can the "guts" of this module be repaired?
2. There are references that this is a solid state module. Is the fuel pump relay inside actually a solid state relay (transistor) or is it a mechanical relay with contacts?
3. If the relay is mechanical with contacts, are intermittent failures usually due to oxidized contacts and if so can they be cleaned?
4. I did notice a post which recommended cutting the wires to the IRCM and installing an external generic fuel pump relay. Of course that would work, but I would prefer to keep everything original if possible. However, if necessary what suppliers and part numbers are recommended?
