Interior Dye or paint
Bryan Brooks
College Station
I know this has been discussed before. But my center console needs to be redone. It has some scratches and faded. The console seems to have softened and the surface seems tacky. What do you recommend to fix this. The interior is gray. Need recommendations on products
NoSlo
SHO Owner
Portland, OR
Unfortunately, I don't recall the gray color of SEM for seats or plastic, but it's between two colors of SEM gray, favoring one a bit. The difference is dashboard to airbag cover.
One awesome NAPA store here used to carry the full line, but now they carry none, I'd guess partially because their display shelf was covered with "test sprays".
NoSlo
SHO Owner
Portland, OR
You can give the plastic a wipe down with 99% isopropyl alcohol (pharmacy) or 95% ethanol (Everclear, liquor store) and see if that dries up the tackiness.
Don't use acetone (nail polish remover) unless you want to remove any paint and melt the plastic.
If it's already far gone, you can see how 0000 steel wool does to refinish it.
Bryan Brooks
College Station
If it seems tacky then it was probably painted in the past and either improperly prepped or incorrect products were used.
SEM is the company that you want. They offer the best products for interior restoration.
What color is the closest match for the gray interior?
kevinspann
Don't take my advice.
Richmond VA
I pulled the top of the center console, coated it in brake fluid, and wrapped it in plastic to dissolve the soft touch coating. Underneath is plastic molded in the right color.
SEM Presidio 15163 is the closest match I found for gray right out of the can.
