Intercooler cleaning
Bronco2fan
Texas
Yes. Orgesmash sent me a link to an indepth thread about it. I'll be checking that tomorrow. Thanks for your input.
Sent from my LGLS991 using Tapatalk
Bronco2fan
Texas
So I got her back from the tranny shop just now. They're under the impression it's the torque converter. Says it more pronounced in the lower rpm range and levels out the faster it goes. Here's the scan pic if you can understand it. 801af4fe04b6fb31f0463b685e8a1206Db6507467bfb1050da233df1dce22dd0
Bronco2fan
Texas
So I take it yours is good? I don't see any rubbing and it looks insulated.
OgreSmash
Austin, TX
Theres a lil rubbing but doesnt look like it wore the wire covering down to the wire. I may tape it up anyways
Sent from my LG-H918 using Tapatalk
Johnbigdog
michigain
So ford has two great Pics for diagnosing a torque converter. TC_SLIPDSD (The commanded converter slip by the pcm) and TC_SLIPACT (the calculated difference between engine RPM and turbine shaft speed). The turbine shaft is the input shaft of the transmission. When TC_SLIPDSD reads 1020 the converter is off. When it reads less than 1020 the com is modulating the converter. When the desired is near 0 rpm, TC_SLIPACT should be following within 10-15 rpm.
The torque converter solenoid needs power to provide converter clutch application. More power more clutch. So the picture shows the converter solenoid on, but the converter is never locking up and staying locked up.
Another little fun fact. If you disconnect the transmission bulk head connector you will have max line pressure, park, neutral, reverse and one forward gear to limp you home. That forward gear is usually 5th. This will happen for most all Ford automatic transmissions that use hudrolic fluid to function.
There is also PIDs GEAR_RAT and TRAN_RAT that can be monitored for a forward gear slip. GEAR_RAT the commanded ratio and Tran_rat the measured ratio using the turbine shaft speed and Outputshaft speed sensors. TRAN_RAT won't work at a stop because there is no T.S.S. and O.S.S. sensor data to make a calculation on. For a slip in first or reverse one must monitor T.S.S. data in gear, stoped. If there is turbine shaft speed 8n gear wheels stoped, a clutch is slipping.
A harsh shift is the way the p.C.M. accounts for a slip. The PCM does not know what a harsh shift is. It only knows that when I demand a say 2-3 shift is should occur in x time. If that does not occurs it ramps up pressure to make sure the shift happens in x time. The driver feels this as a harsh shift. PID data won't show a slip because the P.C.M. has already accounted for the slip. This is where a PID called GEAR helps. It tells one if the transmission in in 1st through 6th gear.
Be aware that all harsh shifts may not be due to a transmission fault. The PCM will do what it thinks the driver commands and reads accordingly. It just wants to make sure it's clutches don't slip too much and become damaged.
Also there is really only 5 things that go wrong in a transmission. The brain box, a wire, a solenoid, a valve, or a clutch fault. The clutch fault includes a hudrolic or medical failure.
There some good old ford trans diag 101 at free.99. Good night.
Bronco2fan
Texas
Damn, that's a lot of information that I half way comprehend lol. I was hoping someone could interpret it and tell me if it really means my tranny or torque converter is cooked and need replaced.
Johnbigdog
michigain
Since the shop is not reporting a D.T.C. a circuit fault is not suspected. But you could still have a mechanical solenoid, valve, torque converter, stator support or turbine shaft fault. There could be high resistance on the circuit too. The PCM can't see high resistance.
If it makes you feel better my 16 with 40k has had about a 100 rpm shudder for a few thousand miles. No D.T.C. yet.
There is a good chance if your feeling a shudder once and a while at a steady state cruise up a hill that the converter is faulted, but I cannot say to jam one in ant it will be fixed.
Bronco2fan
Texas
Well I spent the morning going over every wire with a sensor I thought would affect it. Didn't find anything unusual. Pulled the airbox to check tranny fluid, looked good and level was good too. So I decided to try the band-aid approach. Put some no shudder in her and drove her about 5 miles. I really wasn't expecting it to make a difference. But it did, no shudder or slipping to speak of at any speed. To say I was surprised is an understatement. But then I realize it's still just a bandaid. So if the problem comes back I'll still need a rebuild probably. I'll keep you all posted in any case. I really appreciate all the input and information. Thanks.
Sent from my Alcatel9007T using Tapatalk
