Intake/Valve adjustment Question
SinisterSHO
Rust free
630, IL
If everything works out, I will be doing the upper 60k/120k stuff. Valve cover gaskets/plug wells, plugs, wires, and valve adjustment. Looking on Midwest SHO's site, they sell an intake gasket kit which Mikey told me is everything to take the intake apart, etc. However, I'm confused about what goes to what. http://www.midwestsho.com/catalog/product_info.php?cPath=84_21_41&products_id=45 What exactly are the runner gaskets, and the primary and secondary?
Also, I plan to look check out the timing belt, which I'm thinking has been replaced. I was told the water pumps start to leak around 60k, and mine doesn't leak as far as I know. So, if its had a new waterpump, it probably got a timing belt. But we'll see. Anything else I should look for while I'm there?
Thanks
Dr. Tweak
Mad Scientist
Northern Vermont
Do the CPS so you don't have to worry about it. Check for crank cancer. That's about all I guess... shrug
James Downing
Virginia Tech, VA
The top gasket in the picture is your secondary runner gasket. (your secondaries are the short runners)
The bottom gasket is your pimary runner gasket. (the primary runners are the long ones that run from one side of the engine to the other)
The two 'metal head' gaskets go between your heads and your runners.
<small>[ December 20, 2003, 05:54 PM: Message edited by: James Downing ]</small>
sideSHO
East TN
If you take your intake completly apart to clean DO remember to use ALL gaskets included.I forgot there were gaskets that went behind the horns on the tanks rant A weeks wait for powder coating and 2 hours of labor later I remembered the gaskets. doh
Unless you are planning to competely disassemble the intake to powdercoat or thoroughly clean the interior, there is no reason to take it apart. You can clean a good portion of the runners and plenums without taking the runners apart. If you aren't planning to do a complete disassembly, you only need two of the metal, shim type, intake-to-head gaskets out of this set. You could save some bucks by just getting two of the Motorcraft E9DZ-9439-A from FordPartsOnline.com for $11.90 or FordPartsNetwork.com for $12.49.
You should plan on replacing the valve cover and plug well seal set. Unless you know for sure that the timing belt is less than 20,000 miles old, I would plan on replacing it for its meager $37 cost. That is the best bang for the 60K maintenance buck that you can get. Don't pass up the easy chance to do so.
billh
Moxee, WA, USA
I don't want to get on a rant here, but;
Before I found this group, I had my car into the friendly local, overpriced, Ford store. They were chasing a re-occurring cam position sensor error by throwing parts at the car. (After I got really ****** off, read them the riot act and told them that the problems didn't become re-occurring UNTIL they changed the cam sensor, the light bulb came on! "Maybe Ford sent us a bad cam position sensor!??") One of the parts they threw at it was the CPS. Since it was tore down that far, I also had them change the cam belt. I asked them about the water pump. They said it looked fine, and even though the car had 85,000, since it wasn't leaking I shouldn't worry about it. THREE DAYS after getting the car back, the water pump started leaking. They wanted big bucks to change out the pump. headbang ****** me off so bad, I did it my self.
Unless you have proof that the WP was changed, I would say to go ahead and change it.
Glebtihonniaqw
