Intake Manifold Gasket??
Diameg
Ontario, Canada
Does anyone know the part number for the Upper Intake manifold gasket?
Mine is damaged.
Thanks.
Mike
94 MTX (Rare Green model)
5 cylinder engine
Well oiled spark plug wires
Custom Gas filled mufflers
Several bolt-on stickers ready for installation....horsepower increases to follow.
Which one are you referring to? The intake manifold to head gaskets are the metal shim-type gaskets and are usually reusable. SHO Nut lists these separately as Ford part:
Intake Manifold Gaskets (2) E9DZ-9439-A $27.16
If you have disassembled your intake manifold and are referring to the compressed fiber gaskets between the plenums and the runners, SHO Nut list these as follows:
Primary gaskets (2) E9DZ-9H486-A $12.71
Butterfly gaskets (4) E9DZ-9H486-B $24.08
If you want all of the above, including the IAB gaskets, you would be better served by the Fel-Pro P/N MS94831 for $45.98 from RockAuto.com (or check with other sources).
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Diameg
Ontario, Canada
Scott,
Thanks. It is the Intake to manifold gaskets. I know they are usually reusable, but one of them is cracked and in bad shape, so I figured for an extra $27, why not just put a new one on.
Figures, the reusable ones are $27 but the non-reusable ones in other areas of the engine are always more expensive!
I am leaving the ones for the butterfly gaskets etc right now because I'm going to have my intake manifold port and polished, so I'll take care of that at that point.
I know, people are going to say why don't I do all that at the same time as what I'm doing now but I have to get it running good real fast.
Josh from Sho Nut has some stuff to put on my car and he's just waiting for me, has been for a while now. However, due to the oil in the plug well problem, I have not been able to get down there.
So, I'm doing the plug wires, plugs, plug well gaskets, valve cover gaskets, and now the intake to manifold gaskets.
If that doesn't fix it....I'm selling it and buying a Yugo!
The intake IS the manifold. The intake manifold is bolted to the heads and it is the intake manifold to head gaskets that you are looking for.
It sounds like you would be dollars ahead if you purchased the whole set since you wil be needing the plenum to runner gaskets later.
Scott
Diameg
Ontario, Canada
Oops, sorry, I got ahead of myself there.
I realize the intake is the manifold, I meant to say the intake manifold to head gaskets, just as you suggested.
You're right, I probably would be ahead in the game had I got the whole kit but I actually get good discounts from Part Source here in Canada (due to a relative) and to be honest, I did not think ahead as to what I was going to be doing.
The Valve cover gaskets and plug well gaskets, as you know (since you're the one who's helped me out the most on this!), is to fix that oil in plug well problem.
The butterfly gaskets etc are an after thought, as I just decided to have my intake port and polished.
The intake to head gaskets? Well, I just plain didn't anticipate needing them.
Fortunately, I live in Canada and our money is not ACTUALLY worth anything. It's just for show, that's why it's all those pretty colours.
5 cylinder engine
WaterRooster
Here
Yah I know.....I still have $30 in paper, and about $5 in your "loonies and Toonies"
Shawn
93 Emerald Green MTX
CAI,PP Y-pipe, Dynomax Catback, 80mm MAF, LPM, Ebachs and Tokis
TwiceSHOwn
Atlanta, Ga
Scott, i hope you can clarify the felpro set come with every gasket for the intake? Meaning the butterflies, IAB, Metal spring between the heads all for 45 from RockAuto?
I ask because i think that the number for Intake Manifold Gaskets (2) E9DZ-9439-A $27.16 and you need to of them makes that complete gasket set a much much better deal...
I ordered the above from my local dealer and they tried to say they were 27.16 EACH and you need 2 of them...
93 Silver ATX 57K
LPM
80MM MAF
Y Pipe
Eibach + Tokikos
Front and Rear STBs
Cold air snorkel
TCE SHO stopper brakes
Recovering from its 60K...sigh
The Fel-Pro P/N MS94831 ($45.98 from RockAuto.com) includes the two metal intake to head gaskets, the two IAB gaskets, the four plenum to primary gaskets and the two plenum to secondary gaskets. I am going from memory since I just saw the set last Tuesday.
Scott
