SHOtime2511
CGP
im in the process of building my 3.2L for my 90.
engine is (i think) every bolt on 3.2L with SS stg2 cams.
its also going to see 50-75 shot of zex.fuel pump is a 190lph.
now the question is,will the stock 3.2L 24lbs injectors be sufficient for this build or should i look into somthing like the Ford Racing 30lb'ers?
id like to keep the tuning as simple as possible on this build
All this power, and my best ET is only a 13.56.
I, however am running 3.0 injectors, and I can safely say they ARE maxed out with a 100 shot. The difference from a 75 to a 100 shot of N2O really show's up on the duty cycle. I have 6 little garden hoses. I really think in my application, the 3.0 injectors are definately too small.
