Originally posted by pekin22:
When I start my 93'automatic (when engine is cold), the rpms rise to about 1500 for about 20secs. then settle down to under 1000. When I put it in gear it wants to die. If it dies and I start it again it runs fine. Any ideas?
Originally posted by sdpatt:
The idle program settings are stored in RAM which means that each time the battery is disconnected the settings are lost.
Scott
When you reset the idle settings the later times, did you also apply the loads to the engine within 70 seconds after starting (shifter in "D", A/C ON, lights ON, turn wheel side to side)? If it worked properly the first time and not later times, it sounds like something different in the procedure.
Scott
