Idle problems with my supercharge
jeanrw2000
Lechon Asado!
Brawley, CA
when SS installed my race cams he raised the idle to 1000rpms now that i installed the supercharge i can seem to idle the car for crap,
question why do i need the idle raise with the race cams? and well do they still need to be raise with the supercharger now? :shrug:
NJSHO
Clean Your Shorts!
NJ
Nice Rims. What brand, model, size and how much do they weigh? The idle needs to be raised otherwise you would be on the verge of stalling all the time with the race cams. Dont know about the supercharger.
jeanrw2000
Lechon Asado!
Brawley, CA
thanks,i gotten a year ago so i forgot who make them but, ill check as soon as i get a brake from work and ill tell you later,they are 18"with the tires they weight the same as the 16" slicers with tires, i put them on a scale one time because to me they were looking a big to heavy but i turns out they about the same i forgot exactly what the number was
jeanrw2000
Lechon Asado!
Brawley, CA
18" SPORTS MAX
jeanrw2000
Lechon Asado!
Brawley, CA
92sho16 said:
TeamDynamics Mirage
These look like the same wheel.
yeah they look almost the same, by the way the iddle problem i had was fix a while ago i have to installd a after market fuel pressure regulator, thanks.
car is awaiting for a new clutch master Stage3 and tokico struts before final tuning and dyno runs which me luck. :thumb:
1992SHOMTX
Vrrooommm...pssshhhh
Providence, RI
good luck :thumb:
jeanrw2000
Lechon Asado!
Brawley, CA
Silver95 said:
whats the full list of your other mods and how much boost do you plan on running with?
Car 5,500.00
Hiflow Y-pipes w/cats 379.00 UD pulleys w/belts 169.00
LPM 299.00
80mm MAF 299.00
Cold air snorkell 99.00
4 Namkang tires 436.00
18" SportMax rims 590.00
60K service@58,000 miles 239.00+680.00 labor Valve Cover gasket set 169.00
13" Baer Brake Kit 1,295.00+340.00 labor
Front strut Tower Brace
Rear strut Tower Brace
Full body subframe conectors
H-Brace 399.00+212.00 labor
Hand ported Intake runners
BigBore Butterflies
Race Hyperformance Camshaft kit 1,500.00+680.00 labor
:snicker: DYNO RUN after all that crap!! 238.2hp 188.8tq
Double Core Row Radiator 299.00
13" Rear Brake Kit 399.00
Pillar gauge 44.95
JSP Grand Touring Wing 199.95
Center Force Clutch Burned 516.16+375.00 labor
Intrax Springs 299.00
Supercharger kit 9psi 3,999.00
Aftermarket Fuel pressure regularor 230.00
Stage 3 ClutchMasters 599.99
Ceramic trough bearing 95.00
Tokico Struts 500.00
Awaiting for the clucth to brake in for final tunning and Dyno runs :confused:
jeanrw2000
Lechon Asado!
Brawley, CA
By the way the aftermarket FPR and some other cleaning here and there fixed my iddle problems thanks to all who help me with the nightmare. :thumb: :salute:
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
There are SHO specific kits. You need 94-95 knuckles to get them to work which you have. I used a Cobra Kit for mine, the only thing that was different was the bolt pattern, otehrwise they work. I had to grind the brake hose a little. You can see it on my Car Domain site.
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
Hey Jean, Hows everything going with yourself and the car?!? :)
