Idle Problem
BamSHO
South Williamsport,PA, US
Does anyone else have a problem with the idle on there GenIII SHOs. My dad keeps having the same problem on his 1998. He is on his third throttle sensor, or idle sensor. I forgot which one but, it's the always the same thing. Just wondered what would keep causing them to go bad.
Brian Michael
92 MTX
What is the problem that you are having with your idle? The throttle position sensor is good from well over 100,000 miles of use. The usual culprit in an unsteady SHO idle is the idle air bypass valve. A good cleaning will usually correct its effect. Without knowing what the problem is, it's all a mystery.
SCOTTDW
Memphis, TN, USA
Mine goes to about 1200 after start......then to about 700 in about 30 seconds. Seems to be very consistent.I stay put in the garage until the 700rpm mark.
Scott
98 SHO Silver
K&N Panel
Magnaflows 3" tips
Goodyear RSAs
33K
OzzmanNT
Dinwiddie, VA
Mine is about the same stays at 1200 (if it's cold) then drops to aprox 700. I have not seen any problems develop yet with mine. But if so i'm going to be ******.
1998 Burgandy SHO (Tan leather)
K&N panel filter
Mobil 1 Synthetic Oil
waiting to see what to do next....
OzzmanNT (email: [email protected] AIM: OzzmanSHO)
http://members.tripod.com/shoturbo
smsfordman
mississauga/ontario/canad
the high idle you are referring to sounds like normal cold engine start stratigy but if it is the high idle when vehicle is hot then refer to the TSB on the above post and it should cure it. It requires you to change the connector to the Tps . this may explain why repeated tps changes have not cleared your problem. I did mine last month and have not had the problem since with the new revised connetor. 1998 sho
mholhut
MA
1200 rpm's is a normal cold-start routine for these cars. As long as it settles down to about 700 like you say, the car is fine. The references to high idle's listed on v8sho.com involve idle tachometer readings of 2500 rpm's or more. A noticable difference; otherwise, the car is fine.
Mike Holhut
'96 Ebony Satin
BamSHO
Thank for the help. Oh yeah another thing, do all the GENIII speedo's quit working at 110 mph. My dad's does and i hate it.
Brian Michael
92 MTX
73MM Mass Air
LPM
Cold Air Kit
LASTSHO
MinneSHOta
Brian Michael
92 MTX
73MM Mass Air
LPM
Cold Air Kit
I can almost guarantee that he has a 1998. The '98 SHO's are notorious for speedo problems above 110 or so. No fix as far as I know....
Ford has refused to look into the problem because there is no real use they say...for going that speed. And...no way to test it short of a dyno.
Mark
'99 Black 30K
Lots-O-Mods...
The LASTSHO's Pics
stephen newberg
Ladysmith, BC, Canada
Mine drops out at just about 115 mph. I went up there a second time to be sure, but normally do not travel fast enough for it to be one of those problems I just have to fix somehow.
pax
smn
'98, Black
Mod.Porter intake, K&N panel, SARC cutout, instrumentation cluster, 23mm rear swaybar, 245x50x16 Bridgestone Potenzas
CMurderSHO
pittsburgh,pa usa
i must say i often hit the 125-130 mark coming home at night because there is no traffic at 11:00 at night and there is a huge stretch of road near my house and my speedo works fine. I have a 96 though.
96 silver frost
18" asa js5 wheels
225/45/18 continentals
bullet turbos 3 1/2" tips
open K&N filter
powerslot slotted rotors
superchips chip
asp underdrives
wuzzzer
MN Moderator
St Cloud, Minnesota
No speedo problems here either.
Mark
'97 Pacific Green
http://www.picturetrail.com/wuzzzer
Porterized
K&N Filtercharger
Rhino mufflers (909 series)
17" Team Loco #150 wheels/Dunlop SP Sport 4000 tires
stephen newberg
I think the speedo problem is a confirmed '98 problem only. It is apparently burned in code in one of the computer chips that causes the problem, hence no simple fix. I suspect the determined person could find out which chip, get it read out, trace the ladder code to the problem, write a fix, and then burn a new chip. If they do everything themselves and have and IC burner, a low cost fix. If they have to hire someone and gear to do it, could easily hit the $1k mark.
I could probably read the lader code and find and write a fix, but finding the correct chip, getting the initial print out, and then burning the new chip is past my home attempt ability. If anyone wants help with the part I can do, let me know.
pax
smn
'98, Black
9
98BigSHO
Guest
The problem with our speedo, I believe is how ford has the 98-99 reading ground speed. The 98-99 don't have speedo gear they read speed off the ABS sensors on each wheel. When you get going the fast the signal supposedly get eratic enought that the speedo cannot read so it shut off. I read this somewhere... I think on V8SHO.com.
Mac's 98 SHO
Pictures: http://www.iland.net/~blueoval
smsfordman
Mine is a 98 and I do have the speedo die at 170 km/h or 110mp/h I wish I could have this glich fixed. I have a storry from Ford that might be of interest. Shortly after I purchased the Sho in 98 and found that the speedo did not work at speed i contacted a person I know in the Atlanta assembly plant to see if he had heard of this problem. Well to my suprise he got back to me about six months later and had told me one of their engineers had witnessed this problem himself on some back road test ride . From what they think caused the problem is that on the Sho's in 98 they. installed the same computer as in the 24 v v6's. The v6 are all goverend to 110 mph so there is no need for the speedo to read any higher hence the problem. The Sho's are not goverend but are only drag limited to a top speed of around 140's. This seems to explain why the speedo drops off as well as the odometer while the speed contiues to exceed the speedometer settings in the computer. I asked what remedy there was and did not get a clear response ever . Maybe someone can add or help on this issue because i have tried to pursue this from as many different avenues as possible with no sucess because I guess the vehicle population is so low and for testing liabilities.
SilverSHO
cartersville
That would be the Duratec V6, not the SHO V6. My mom has a '98 Sable with the 3.0 Duratec V6, and it indeed will not go over about 110 or 111 MPH. I verified this myself late one night on a dark stretch of interstate.
Nick Draudt
Lt. Titanium 90, 133k
Coneless, ACCEL 8.8 wires,
SHO Shop torque limiters,
Cherry Bomb Turbo II mufflers, and new CV boots sitting in my room
AIM: loudog6491
FIREMT1977
