I need a muffler shop
97SHOgt
Cincinnati, OH
Does anybody know of any big name muffler/exhaust shops that I could find around Cincinnati that would weld with stainless steel wire and put on stainless steel pipe. I want to do the setup with 2.25" Pipe after the y-pipe, into Magnaflow or Borla mufflers, with 2" pipe running from the muffler to the tip. I want the sound bad but I think it would be very dumb to cut off a good exhaust just to put on one that will rust out in a few years. I went to CarX and they don't weld with stainless steel, and they use aluminized pipe which they said will rust. So they are off the list. Anybody have an information or suggestions?
97SHOgt
Cincinnati, OH
I'm a couple blocks from UC in Clifton, in a nice area that is. My apartment has a parking lot that is closed off so I guess that's the most important thing. Maybe I'll run into you sometime. You don't weld do you?:)
Motoman991
Cincinnati
I took a welding class in school a few quarters ago but I'm not good at it compared to the instructor. I had mine welded at moorehouse welding out near eastgate. I go to UC, but I go to the College of Applied Science of Victory Parkway.
Mr Anonymous
Tire Wall
You're not likely to find anyone welding with stainless at an exhaust shop. You're going to need to find a welding shop that's willing to weld your exhaust.
Motoman991
Cincinnati
I was assuming you were talking about cam welding. Moorehouse welding might be able to weld with stainless steel wire but I am not positive. I don't know the phone number for the place or I would tell you.
97SHOgt
Cincinnati, OH
What is your name, I go to the OCAS also. Construction Management, I'm sure I've seen you out there, no that I think about it, I might have seen the car too. My cams were pinned when I bought it. I'm talking about the exhaust. Where is this Moorehouse Welding?
Motoman991
Cincinnati
I have seen your car in the parking lot. Morehouse welding is right off of tealtown rd. I found the phone number for the place. Its 513-752-2236. The address is 4819 Tealtown Rd. The place is kind of close to the Eastgate mall. I go to ocas for mechanical engineering. My name is chris strickland
