StealBlueSho
FWIW... never seen a post on this forum where someone ran into that issue with the 160F thermo...
Do you have a visual inspection or just reading OBD monitors? The DPs may be an issue, seems like PPE catted is the only ones that will not throw a code with the rear O2s turned on. The normal 3bar tune should not have them turned off and should pass OBD monitor readiness without issue.I live in a state with emissions testing so I guess I will have to switch the 3bar and downpipes back and forth every couple years.
I haven't had an issue with the 160 stat in NY winters.
