I Just Pulled the Trigger
StealBlueSho
NA
FWIW... never seen a post on this forum where someone ran into that issue with the 160F thermo...
2011TAURUSSEL
2014 SHO LMS Stage 1 V10
DFW Metroplex, USA
Trust me after two winters that seems to be the common denominator. Sensor itself looks fine, wiring looks fine not much else to narrow down. The reason I didn't get during the initial tune installation was I did not install until March and by that time it wasn't that cold anymore. When the P0128 comes up that is the only code. I do not just blindly clear the codes pull from the scanner then clear. One thing new this year that may be a factor was I had the Coolant flush at the dealer at the end of March. I don't think that I had an air pocket because I wasn't losing coolant except during the initial thermostat replacement which is normal. After I topped off the reservoir it stayed normal.
Lostneye
NY
I haven't had an issue with the 160 stat in NY winters.
I live in a state with emissions testing so I guess I will have to switch the 3bar and downpipes back and forth every couple years.
Do you have a visual inspection or just reading OBD monitors? The DPs may be an issue, seems like PPE catted is the only ones that will not throw a code with the rear O2s turned on. The normal 3bar tune should not have them turned off and should pass OBD monitor readiness without issue.
Madyaks
Madyaks
Valley Park Missouri
thanks
