GordoSHO
. I have a questions to ask about the electronics on headbang my car. I had to jump start my car and I hooked the jumpers wrong on the Jimmy that was helping me. Since then my climate control will not work and the fan is on high all the time. There is no speedo and the trans shifts are not right. I am worried that there might be other things out that i do not know about! I found one 10 amp fuse burned out under the dash and none in the engine bay. I got a new ECU and after looking at the problem I do not think that the ecu went out. My car is in limp mode and starts fine and idles fine. The ABS light is on in the dash to. Everything else works fine like the lights and the alarm. I am going to scan it, but I have a feeling that it is not going to give me anything to work with. Has anyone ever had this problem before? Are there fusable links somewhere I do not know or fuses somewhere eles in the car? I have to get my cams welded on 05-19-2003 and I need to have it fixed by then to drive up. Let me know what you think and let the bashing begin of my stupidity. thumb headbang
