how to reset the idle?
Status
Not open for further replies.
rktmn
Well-Known Member
miami
I have done several searches on how to reset the idle on the MTX, but I cannot find the procedure. I even looked in Shotimes.
Found something on turning the lights on and off, but I coul not find the complete procedure.
Can someone link me to it?
Thanks.
Jose
Search keys: idle speed reset procedure
NOTE 1: The Ford owner's manual directs that the idle program be relearned following any service when the battery has been disconnected. To do this, it states that the engine should be started and allowed to idle for the (approximately) 70 seconds without touching the gas pedal. Adding the accessory loads ensures that the EEC and IAC valve can accommodate the additional air flow requirements and still maintain the programmed idle speed.
NOTE 2: It is preferable that the car be driven immediately after setting the idle programming. While driving, allow the coolant temperature to rise to the normal range and run the car through its entire performance range.
Idle Speed Program Reset Procedure
1) Disconnect the negative battery terminal.
....Optionally, disconnect the keep alive memory (KAM) connector in the small
....wire also landed to the negative battery terminal.
2) Wait at least 30 seconds.
4) Reconnect the KAM connector or negative battery terminal.
5) Start engine normally (never press the gas pedal).
6) Allow the idle speed to settle for at least 30 seconds.
7) Within 70 seconds of starting the engine, concurrently apply all accessory loads.
....a) Climate control to MAX A/C.
....b) Headlight switch ON, brights ON.
....c) Turn steering wheel slowly ~1/4 turn side to side.
....d) Press brake pedal.
....e) ATX SHOs only: shifter to DRIVE.
8) Do not turn off engine for at least 5 minutes.
rktmn
Well-Known Member
miami
Thanks Scott.
I'll give it a try.
Jose
frosty the sho man:
There's a procedure in the Ford emissions book for setting the base idle too.
There is, but you should never have to adjust the base idle speed.
Axianator
I am a banana!
Roanoke, TX
FWIW, the 10 minute battery disconnect wait time is completely unnecessary. KAM contents should be destroyed or corrupted within a few seconds of power being interrupted to the EEC. There is no need to "hold the brake pedal", "turn the headlights on", or "wait at least half an hour so that the computer is drained" as popular thought has dictated for so long. All you must do to ensure KAM erasure is disconnect your negative battery terminal for at least 30-60 seconds and you're good to go - any longer than that is unncessary. You may also use the PCM's black grounding plug on the passenger-side strut tower as a substitute, if you wish.
Just a little FYI for all the previously mis-informed folk out there. ;)
BlownByU
Guest
New York
So what's the big benefit of resetting the idle correctly? I never do and my car seems to run pretty good for the most part :D
DigDeez
Chicago
Allot of times when I'm trying to reset the idle, it just doesn't work. Yesterday, I put on another new TPS, and my idle seems to be where it should be.
Axianator
I am a banana!
Roanoke, TX
All it does ("it" being "resetting the idle") is clear the data that is stored in the Keep Alive Memory (KAM) area of the computer, such as short and long-term adaptive fuel trims, ISC adjustment values, etc. Doing this is most beneficial for people who are (re)installing a chip with a different calibration onto their computer - cleaing the KAM of it's stored values will help the computer to start with a "clean slate", so to speak, rather than back-tracking from the values that were previously stored in it's memory. :)
SASHO91
Zoom Zoom
San Antonio,TX
this kinda goes along with this thread. at what rpm does yalls shos idle at. mine idles at 900 to 1000. just curious. :D
Axianator
I am a banana!
Roanoke, TX
Base idle for all V6 MTX computers from the factory is 800 rpms. ;)
PAracer
West Chester, PA
Is there any reason to unplug an aftermarket chip like an LPM when resetting the idle? Also, is it really that important to do this when installing a freshly burned chip?
Axianator
I am a banana!
Roanoke, TX
No and yes, respectively. ;)
autobahnsho
SHO Victim
NY for now, WY for real
They are all supposed to idle at 800rpms.
After I replaced the Crank position sensor, (and replaced the timing belt) the tach was always around 100 (1000) rpms too high,
compared to before the sensor konked out.
shojuan
sunny San Juan Bautista,
The tach isn't known to be completely accurate.
Jason Bowles
Curious Kid
Lacey, WA
This might go along with this thread
I have a 93 Sho and I was wonder what the rev-limiter is supposed to be set at on this generation SHO. Mine is at 3800 and I've been told thats quite low.
Please Help
Jason Bowles
Curious Kid
Lacey, WA
Secondaries
It is my understanding that the rev limiter is only for when the car is in neutral. When in drive it has no problem shifting right before redline while punching it. The only reason I ask is cause I was giving a truck a jump and I happened to hit 3800 RPMs and the rpms jumped as the car shook. I was concerned so I asked around what the **** it could be and they told me it was a rev-limiter and they've never seen or heard of one being so low. I'm not a mechanic and I dont race cars so I'm pretty cluess when it comes to cars - it's just nice to know the power is there when you need it.
Thanks
Jason
Status
