svtman
I will shortly be replacing my sagging rear springs on my SHO. I will probably also get the strut mounts in case the old ones are worn. What is the exact procedure to replace my springs? The struts are fine and do not need replacing. Are there any visible signs that the mounts will be worn as well other than the clunking that I think they are causing?
Thanks!
Thanks!
