How to remove rear downstream O2 sensor?
autoteleology
Midwest
I am trying to diagnose a P0420 code and I am in the process of replacing my O2 sensors. I have replaced the upstream sensors (from a prior fix) and the bank 2 downstream sensor, but the bank 1 downstream sensor is stuck in the catalytic converter hard. I wrenched on it with a (crappy) flex head ratchet for a good hour or so last night with Gibbs penetrating oil before giving up and putting my car back down so I could drive to work for the night shift.
Does anyone have any suggestions for a good tool / process for getting it out that hopefully will cost less than just having a shop deal with it? It's in such an obnoxious position that it's hard to get any direct mechanical leverage on it.
C88fa4f7 56ca 4e64 b7b9 44d4af841ce1
autoteleology
Midwest
Heat. A propane torch would probably do it. Don't burn the car down.
A new cat is probably the only solution to a P0420 code.
It's more likely than not I need a new cat (given my prior PCM/injector issues) but if I do, I need to replace the O2 sensors anyway, so I might as well do it first and see if it helps before spending a lot of money.
If I do replace the cat(s?), are there options on the market I should go for over something stock equivalent? I know there's been a crackdown lately on tuning in terms of environmental regulation, downpipes used to be one of the most common upgrades from my reading but is it even worthwhile to try to get more performance that route any more?
kryptto
South East, Florida
Stainless Works, Magnaflow or PPE
SHOrod
Torrie Tuned
Cedar Rapids, IA
Are you using the spark plug style O2 socket or the offset oil pressure switch style crowfoot O2 sensor socket? You might have better luck with the crowfoot style and an extension to get the wrench below the exhaust where you can get a bit more leverage on it.
-Rod
autoteleology
Midwest
I realized that an extension bar will probably work given I have offset O2 sockets. If that doesn't work, I'll get a proper breaker bar, and if it's still stuck, a propane torch to heat the bung.
I'm not very mechanically inclined, but I am trying to teach myself to be, and this forum has been very helpful in doing that. Thanks for the help, everyone, I'll let you know when I get it off.
kryptto
South East, Florida
so the propane torch IS the best way to break the "seal" of a O2, like Texas mentioned, be careful with the flame. There are a TON of YT videos that show the procedure.
autoteleology
Midwest
Hi, just wanted to provide an update on this, even though it's minor it might help someone.
So, ultimately, all I needed was a really big torque wrench to break it loose (and I even managed to avoid busting my knuckles). This is what I used, it telescopes to a very long length and it also has the perfect angle to hang down from the O2 sensor socket and still be horizontal enough to provide efficient leverage when you pull.
Screenshot 20240729 093208
I also used Gibbs Penetrating Oil (courtesy of Project Farm's recommendation):
And here is the socket set I used (though I believe you can just borrow a set from Autozone or Advance Auto Parts): https://www.amazon.com/gp/aw/d/B07KT1GR7V?psc=1
Screenshot 20240729 092927 Firefox
This is probably all super novice stuff to most people, but I ask for help a lot here, so I try to give back to the forum however I can.
Bronco2fan
Texas
That's funny, because that's the wrench I use for my lug nuts. I have 3 of them. Everything with a spare tire has one in it.
autoteleology
Midwest
That's exactly why I happened to have it lying around only to realize it would work perfectly for this task. I got it for my truck a long time ago after seeing it recommended on Wirecutter
Screenshot 20240729 093945
autoteleology
Midwest
Oh, and one last thing - replacing the O2 sensors did not in fact fix my P0420 code, it looks like I need a new catalytic converter to get rid of my check engine light.
It's not a priority for me to replace since we don't have emissions testing or inspections in Ohio (which is incredible given how cars fall apart here due to the massive amount of salt we use in winter), but if I do, any advice on what I should get?
I noticed that it wasn't even a category on car-part.com, and I figured they all just got recycled because the materials are so valuable, but apparently it is illegal to buy a used catalytic converter for reuse.
Also, would I be able to get a decent amount of money back by selling my old converter for scrap?
BradM
Look at O2 Extender instead of new cat.
autoteleology
Midwest
Very nice, I appreciate that a LOT. Thank you for the advice!
I purchased this one, an adjustable right angle adapter, because of the layout of the sensor makes the positioning very finicky. I'll report back how the order process goes, if it fits properly, and if it solves my issue.
Screenshot 20240729 102907
Jimmy SHO
Minnesota
Did it end up working out???
raymo23
