how to remove front speakers, i cant!!!!
raven
cleveland, ohio
i have a gen 2 sho
and i need to replace all of my speakers.
how do iget the front door panels off ?
also, the rear ones?
thanks
smokesho
Ont,Canada
there are screws around the door handles....and sometimes behind the small light panels......remove the screws from the door panel....carefully peel the door panel back and look if it is held by any clips.... BE CAREFUL!! this is basically how the doors on any car can be taken off...
Bizzy
Originally posted by raven:
i have a gen 2 sho
thanks
The rear deck covers can be removed by gently prying up on each corner with a butter knife or putty knife. There is a bracket in there that you'll need to undo and the sub is in a rubber basket type deal that you'll need to undo before you can remove it.
As smokesho said, be very careful when prying the door panels off. If you damage those clips your door panel will be loose forever and ever amen.
Proud to be an American!
Beth
'91 Plus MTX, Mostly stock
K&N Filter, Coneless
Colgan Custom Bra
Racing Series Driving Lights
Mods in the works
Many items on wish list!
raven
cleveland, ohio
thanks all
bizzy;
arent the gen 1's different than the gen two's though, speaker wise?
you have a gen 1 right?
white94sho
Berea, OH
I had to remove the back seats in my 94atx to get my rear speakers out, because you have to lift up the package tray to get the speaker sheilds off. On the front doors put your fingers in the bottom between the panel and door and pull out. What part of Cleveland are you in.
Mark
Berea, OH
Bizzy
thanks all
bizzy;
The speakers themselves could be a little different, but the bracket in the front door is the same. The rear deck I thought was the same...my friend has a gen II and those came off the same as mine. I suppose he could have changed it out, but he didn't tell me if he did.
Either way the clips can be damaged easily in removal and when you put it back on. They are just plastic and bend easily.
Beth
Colgan Custom Bra
Mods in the works
Dave Ladely
Seattle, WA
i have a gen 2 sho
thanks
You SHOULD buy the door clip removing tool from Snap On, also buy a few extra clips.
Otherwise you will likely damage the clips.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Um I changed m front speakers and being the way I am i just ripped off the door panel after removing the screws. Destroyed all 14 clips in the proccess. So I went down to Ford and picked up 40 or so for about $2. So destroy them all you want.
92 White SHO
HiRevs Competion Clutch
SHOSHOP Engine Mounts
Koni Shocks
StrutTower Braces
UD Pullies
Awesome Sound System
myculito
