How to get only FOGLIGHTS?
Safsbay
Los Angeles
Is there a (simple) way to rig up your lights so you can have just the foglights on without the headlights?
Curious,
Steve
'93 Silver ATX, 80k stock
Just sold the Grand National :-(
Philly area
SHO2NV
Not low anymore
Angola, Indiana
Yeah, just follow the link. If I can do it anyone can!
John
Green 94 ATX
SHO 2NV
[This message has been edited by SHO2NV (edited 12-01-2001).]
FordLover
Houston, Tx
I was sucessful in doing this mod on my silver 92 , but when I did it on my 93, it didn't work. I'm assuming something is different. Anybody know if Ford used a relay or something? The wires were thiner on my 93 than they were on my 92.
-Martin
qiksho
SHO Addict
Fargo, North Dakota
I tried that mod about a year ago and got really ******. My wires weren't the same color as the ones in diagram. I decided to cut them and try different combinations till I got it right. Is all i did was blow fuses and never got the right combination.
SO I resoldered them and heat shrunk them. If anyone knows how hook it up on a 89 please let me know.
Gez89SHO
LEGO SHO
NE Philadelphia, PA
89's don't have relays for the fogs, so the shotimes info won't work. I tried that and ended up blowing fuses also, so what I did was connect them to the cigarette lighter.
Just ran a wire from the lighter to the fog light switch wire, now they work without headlights. The warning ding doesn't work with them this way though, so it's easy to forget them on.
Gezim
1989 Currant Red
coneless, painted SHO lettering
Subframe Connectors, 16x7 Team Loco 143's
gzim.freeservers.com
LSHOC member
[email protected] IM: gzimi
qiksho
SHO Addict
Fargo, North Dakota
which wire? There are three of them and two in back of cigarette lighter? Ok u have power, ground and relay on/off? so u hooked relay to what?
93ATX SHO OFF
Basehor, Kansas, US
i did the mod to my 93 and the wire colors matched up perfectly to the directions by shotimes. Mine come on with my parking lights. At first I had some trouble understanding the directions, so if you need any help, drop me an e-mail.
Gez89SHO
LEGO SHO
NE Philadelphia, PA
I connected the positive (power) wires. There is no relay, I just have a wire running from the lighter positive, to the switch positive.
I'm still using the stock fogs (with 100W bulbs though), so everything else is stock wiring.
Gezim
1989 Currant Red
LSHOC member
FordLover
Houston, Tx
Like I say, I did it on my 92 without any problems, it just didn't work on my 93. I will try it again, but this time I will use a volt meter and make sure it will work before I start cuting wires again.
-Martin
myculito
