How to fix a nose dive while braking.
1993MTXSHO
Its a Taurus...
Jersey
Well guys before my car exploded it used to nose dive a decent amount. Its got koni/eibach with a 24/26 combo. I don't have bias plugs or anythign like that and was wondering if there was anything I could do to make it stay flat while braking. My buddies bmw stays so nice and flat while braking im really jealous. Course thats a rwd and doesn't have such a heavy front end could that be part of the problem and would bias plugs help? Im also thinking of cutting one coil off my front springs before putting my car back together would that help any or make it worse? Im doing it because my front wheel gap is bad even with stock size slicers on it, my summer wheels just make it even worse.:thumb:
EDIT: I do have the 12.5" baer pbr kit up front and the 11.6" rear kit
HotRodKid
mmmmm ... turbo
Western NY
lowering the front will only make things worse. the best option is to have the car sit level while at rest
brake dive is a function of a number of things:
weight
weight placement
suspension design
strut valving
spring rates
moving the battery to the very rear is one of the few things you can do about weight placement
some more antidive angle on the front struts could help (or could cause bind, depending on how much is already built in to the car)
stiffer rear rebound / stiffer front compression valving in the struts will help keep things level
softer springs in back and sligthly stiffer ones up front could also help
mind you, the best strut / spring combo is the one that allows you to drive the car as hard as you like, without causing to much under / oversteer in most situations , so changing that stuff to reduce dive could cause the car to have less desirable charateristics in other more important aspects of handling
1993MTXSHO
Its a Taurus...
Jersey
oh, ok maybe I should leave it alone because the car handles pretty damn well I must say as it is. I should move the battery to the trunk but I don't want to use a regular battery, I want it to be sealed so no gases vent into the cabin and my battery is going to be brand new when i put my new engine in (battery I have now is shot but under warrenty).
1993MTXSHO
Its a Taurus...
Jersey
ok this is a dumb question but how do you adjsut the front konis, I know on the rear you jsut turn the **** which i cant because one of mine is busted and cant be adjusted anymore but I think the fronts are ok but I don't know how to adjsut it.
1993MTXSHO
Its a Taurus...
Jersey
SHOtime2511 said:
id try bias plugs.
just be aware that it changes the breaking chariteristic of the car dramatically
how so, rear end fly out easier?
Cocoa,Florida
yeah thats about right,what you might expect from increase rear break force.
personally i like the way it feels,combined with ALSFB's 24/26 swaybars.
1993MTXSHO
Its a Taurus...
Jersey
ok maybe ill give them a shot iv got that combo with the alsfb so maybe ill liek it. You dunno how to adjsut front konis though do you?
1993MTXSHO
Its a Taurus...
Jersey
K-Dawg said:
Turn the **** on top of the strut. Same as in the back.
umm I guess im a ***** or mine are broken, because iv looked and dont see anything. I have a stb up front maybe thats covering them?
SinisterSHO
Rust free
630, IL
Are you positive you have Konis? Theres nothing thats going to cover up the adjuster. You just need the Koni **** which goes on the top of the strut. I have seen seized Konis, though.
However, the best way to stop nose dive is to not stop.
Mels
SHOVELHEAD
Brookfield CT
You can also use a (forget the correct size) tiny six-point 1/4" drive socket. The adjuster sits nicely in two opposed points of the socket.
SinisterSHO
Rust free
630, IL
Regardless of how you adjust them, its obvoius that they are adjustable.
1993MTXSHO
Its a Taurus...
Jersey
well I have the knobs and I know for a fact that I have rear konis and im pretty sure I have fronts, but I guess i could be wrong. Maybe I have tokioes up front were they yellow? I remember some sorta of yellow thing in the front shock. I was told when i bought the car that it had konis. Maybe Ian can chime in Manyshos he know all but one of the previous owners of my car.
drivinhard
Gainesville, GA
Try a gen3 subframe with the true LCA's (vs the gen1/2 quasi arm with the tension strut). It'll help nose dive.
1993MTXSHO
Its a Taurus...
Jersey
whats that? I am taking my subframe out in a week, but this is a mtx so will the gen 3 subframe bolt in?
naval-avi8or
Chesapeake, VA
Have you or do you know someone who has done this or are you compairing a GEN 1/2 to GEN 3. The lack of nose dive while braking for GEN 3's is a result of the SARC system. SARC adjust the shocks automatically to prevent nose dive while braking. SARC for a GEN 2 would take some modifications to work. I know this because I'm currently retrofitting my 94 back to stock strut system from a 97 SARC system.
