SHOstuff
How easy it to change a water pump? shrug
It will take about a day of your time if you haven't done it before. You have to take off a lot of stuff to get to it. If you go ahead and do it, make sure you don't crimp the o-ring that seals it up on the tube that leads to the engine. The o-ring can also slip off of the tube and cause a leak. I recommend testing the seal with water before putting it back together.SHOstuff:
